Retro fit Oil Hot water
Jon_7
Member Posts: 2
We currently have a 2800 sq ft. Cape. We have electric heat with a 61,000 btu Pellet stove(Harman)in the living room. We are looking to add an oil furnace with forced Hotwater Baseboard for both floors.
Our installer is leaning towrds a Peerless WBV based oil boiler.
How are these for cleaning, trouble free, price, etc.
Thank You And Thanks for the board!!
CLEANING
As for cleaning i'de go with buderus equiptment 2 bolts and the combustion chamber and all flue passes are avableable to be cleaned no ceramic chamber to be replaced and a better insulated jacket then most american boilers and the cost difference is minuim and leveling legs on the boiler top notch stuff that makes servicing a brezze just in case the service guy is a bit run down .I've found them easier to clean them to the point where there as clean as the day they went in i find that a little hard to do with most american boilers given the time you get to spend on cleaning a boiler .Check out therer stuff you will not be wasting your time peace clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Since service is done on
either a contract or time and material or flat rate basis don't get hooked into brand names. Buy the unit your service company feels the best about. Never buy a Chevy from a Ford dealer, FACT!0 -
Thats the boiler my installer recommended. In fact he has the same one in his house. I was just trying to get other peoples views on it.
If the guy who is going to
service it has it in his own home, why do you need more info?
If you trust him, buy it from him. If you don't, well......
There are no 'silver bullets' and a panacea is best served well with maple syrup, :-).0
- 117 Geothermal
