Are all hydronic guages the same?
Butch_3
Butch_3 Member Posts: 5
I have a question. I have 2 properties. One is a duplex with an apartment on each floor and a single family home. My question is this. Are the guages on hydronic boilers supposed to all read the same? I have 2 boilers in my duplex and I am not exactly sure what the pressure is supposed to be cold and hot. The same goes for my other boiler that is a gravity fed boiler in my other house. Do they all operate off of the same PSI? The 2 boilers in the duplex are 40k BTU's and the other one is 100000 BTU's. The assumption is that cold it will read 8lbs and hot anywhere between 20&25lbs. Is that correct? Thanks in advance for all your input.
