Further info on pH for Aluminum
George_10
George_10 Member Posts: 580
the pH range for Aluminum and its safe areas. This info suggest that the safest area for Aluminum is around 8.0 on the pH scale.
Compare that with the acid affected metals.
Or even iron.
  • George_10
    bump
  • S Ebels
    S Ebels Member Posts: 2,322
    OK George, I'll bite
    What are we seeing here and how would this effect a system with mixed components? IE; ferrous and nonferrous?
  • jerry scharf_2
    jerry scharf_2 Member Posts: 414
    gold plated systems
    George,
    I guess we found the reason for it, as long as it's on the inside. :)
    jerry
