Further info on pH for Aluminum
George_10
Member Posts: 580
the pH range for Aluminum and its safe areas. This info suggest that the safest area for Aluminum is around 8.0 on the pH scale.
Compare that with the acid affected metals.
Or even iron.
Or even iron.
bump
OK George, I'll bite
What are we seeing here and how would this effect a system with mixed components? IE; ferrous and nonferrous?0 -
gold plated systems
George,
I guess we found the reason for it, as long as it's on the inside.
jerry
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
