Draft Hood vs Barometric
This has been a very interesting read
I see your problems south of of "the line" are really no diferent than ours. I was going to jump in earlier when the discussion turned to replacing draft hoods with barometrics, but am glad I waited. While there used to be some negociating latitude with enforcing authorities, when it came to ensuring proper drafting, that is not the case any longer. The equipment MUST BE installed as engineered PERIOD!!. If it doesn't work -- find something that does.
I too remember the "eyeball and cigar" setup. It may not have been perfect but at least every old timer worth his salt did it. Today everyone is in too much of a hurry to take the time required. Most ASSUME (that word) the manufacturer engineered and set the equipment up at the factory and nothing further is required on field startup. NOT!!
While some of the old time finesse has been taken out of the equation when it comes to set up - the requirement to accurately check and adjust the parameters has become even more critical. In my area it is estimated only 1-2 in ten installers/service personell own or have used combustion analyzers to set up equipment at startup. Even less use test decices during routine service.
Until it becomes mandatory, or something serious happens, this practice will continue. Consumers installing their own equipment only adds to the problem.
In my opinion this just leaves another opportunity for another level of beauracracy - something we all need!! NOT!0 -
Glenn if that job was near the airport in
Warwick, RI, I was involved in the final investigation of that incident. Just curiious as it sounds like the same case. If it is I can add a little more to what actually happended.0 -
GEEZE BOILER GUY!!!!
Your post was AWSOME!!!!!!!!!
I have been saying this for quite some time now, "Industry police thy self, or big brother will do it for you".
Your post is 100% to the point and 100% accurate.
Nothing I could add.
Grand slam man!
Mark H
Not the same one
This one was out in Coventry and happened about 8 or 9 years ago if my memory is correct.
Glenn Stanton
Manager of Training
Burnham Hydronics
www.burnham.com0 -
Someday
I'll be crazier than you Obi Wan.
Then again...........I may already be!!!!!!!
Thanks Jim.
I sleep better because of what you taught me.
I hope to see you again soon.
Mark "Luke" H
Thanks Mark
Try to call 'em as I see 'em. Are you gonna make Wetstock? If so I hope to meet you.0 -
I take Jim's Class every time it comes to town
because I always pick up something new. I originally, took his class - and met Mark Hunt in the process, because I always worried about CO and wanted to learn about it. Once you get the combustion testing eqiup all you wanna do is test and learn. Mad Dog
Does Vince work for
Water Furnace International?? If he does, I know of him.
Good on you Jim,
ME0
- 109 Chimneys & Flues
- 975 Plumbing
- 386 Solar
- 17 Recall Announcements
