Munchkin w/ Space Pak Hydro/Chiller(jalcoplumb)
jalcoplumb_2
jalcoplumb_2 Member Posts: 172
I am looking at installing a Space Pak unit with a hydro-air coil for heat and a chilled water coil for A/C.
I am looking at the indoor chiller that Space-Pak has listed.
I will be using a Munchkin for the heating plant and a Super-Stor Ultra for the domestic hot water end.
The building needs about 70,000 btu of heat and I am looking at about 5ton cooling.
Any one use the chiller before?
  • Mike Reavis_2
    Mike Reavis_2 Member Posts: 295
    My Unico dealer had one that looked well built
    but I have not had the opportunity to use one. Would like to hear how yourd turns out. The Space Pak dealer also had one, but the unit was not made by Space Pak.
    Mike
  • jalcoplumb_2
    just looking for ...
    input form someone that has used the Hi-V chiller system.
  • Matt_21
    Matt_21 Member Posts: 140
    we installed a
    unico chiller at a rectory last year. it was attached to 7 unico systems. the system worked very well. never had any problems or callbacks on it.
