Munchkin w/ Space Pak Hydro/Chiller(jalcoplumb)
jalcoplumb_2
Member Posts: 172
I am looking at installing a Space Pak unit with a hydro-air coil for heat and a chilled water coil for A/C.
I am looking at the indoor chiller that Space-Pak has listed.
I will be using a Munchkin for the heating plant and a Super-Stor Ultra for the domestic hot water end.
The building needs about 70,000 btu of heat and I am looking at about 5ton cooling.
Any one use the chiller before?
My Unico dealer had one that looked well built
but I have not had the opportunity to use one. Would like to hear how yourd turns out. The Space Pak dealer also had one, but the unit was not made by Space Pak.
Mike0 -
just looking for ...
input form someone that has used the Hi-V chiller system.0 -
we installed a
unico chiller at a rectory last year. it was attached to 7 unico systems. the system worked very well. never had any problems or callbacks on it.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
