EDR
Anyone have a scan of "Engineers' Data for Vento Heaters" that they're willing to share?
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,686
    Here you go
    Vento
    Retired and loving it.
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    THANKS DAN!!!!
    Will print for reference and forward on to the person in need! Did I miss it in "The Library"?
    Noticed a typo in EDR:
    In the index under "American Radiator Company", "Ventor" is listed as opposed to "Vento".
  • DanHolohan
    I added it to the Library
    after posting it here. Thanks for the keen eye.
  • t. tekushan
    t. tekushan Member Posts: 141
    mmmmm....ventos.........
    I just want to thank everyone in the past who helped me when I needed the same information. I was able to do a good recalculation of vento size needed based on the reduced amount of fresh air intake we now need on our theater's heating system.
    -Terry
    Here's another Document
    Might help when sizing boiler replacement.
    70° output was the standard design temp for air entering the room.
    Typical design velocities were 100 ft/minute for 1st floor; 200 ft/minute for 2nd floor; 300 ft/minute for 3rd.
    A bit more detailed table for standard design velocities shows:
    (Elevation between center of registerand center of steam indirect radiator):
    3-5' (1st floor) - 180 ft/min
    10' (still 1st floor, register about 7' above floor) - 240 ft/min
    20' (2nd floor) - 360 ft/min
    30' (3rd floor) - 420 ft/min
