condensate aux. system
bob young
Member Posts: 2,177
any comments for manufacturer preference of pumps on baseboard loops off steam system? was using taco 007 but last two failed in very short time frame. pumping out of boiler.
Are you using
any bypass to temper the water at the circ???0 -
no bypass
installed without bypass but i can see i may have to possibly change my thoughts on that.0 -
You probably need a bypass as the water is to hot for the pump. Also a bronze body pump is best. Get a copy of Dan's book on this site "How Come" It ells you exactly how to pipe and install this
Ed0
- 167 Indoor-Air Quality
