Help - steam boiler makes shuddering noise after turning off
dan_23
dan_23 Member Posts: 4
I havent gotten my steam boiler ( one pipe system ) tuned this year...many times after is done firing I hear a shuddering ( vaccuum ? ) type noise afterwards for about 5 seconds...what the heck is that ? thanks
  • dan_23
    I havent gotten my steam boiler ( one pipe system ) tuned this year... AND many times after is done firing I hear a shuddering ( vaccuum ? ) type noise afterwards for about 5 seconds...what the heck is that ? thanks
  • tommyoil
    tommyoil Member Posts: 612
    Is it
    Oil or Gas? Also name and/or model number wouldnt hurt.
  • dan_23
    it is oil. unit is about 30 years old ( burner newer - Carlin ? )...I lived in the house 8 years...first time its ever done this - the sound is almost like a purring / vibration sound...only happens after unit has been on...then it shuts down...then purrs for about 5 seconds then silent...thanks for nay help - Dan
  • dan_23
  • gilligan
    gilligan Member Posts: 18
    carlin
    if it is a carlin burner, ther's a good chance the end cone is coated with carbon. usual cause is too much draft, it pulls the fire away from end cone so the nasty stuff doesn't burn off like it should. very common in windy areas.
  • tommyoil
    Sounds like
    flame continues after burner cuts out. You'd probably be best served by contacting your oil companys service dept or someone else qualified to take a look. I think service may be in order.
  • Al Gregory
    Al Gregory Member Posts: 259
    Very common with 99FRD, Also need to check pump presure and angle of nozzle. Carlin's like 60 degree nozzles
