Help - steam boiler makes shuddering noise after turning off
dan_23
Member Posts: 4
I havent gotten my steam boiler ( one pipe system ) tuned this year...many times after is done firing I hear a shuddering ( vaccuum ? ) type noise afterwards for about 5 seconds...what the heck is that ? thanks
I havent gotten my steam boiler ( one pipe system ) tuned this year... AND many times after is done firing I hear a shuddering ( vaccuum ? ) type noise afterwards for about 5 seconds...what the heck is that ? thanks0 -
Is it
Oil or Gas? Also name and/or model number wouldnt hurt.0 -
it is oil. unit is about 30 years old ( burner newer - Carlin ? )...I lived in the house 8 years...first time its ever done this - the sound is almost like a purring / vibration sound...only happens after unit has been on...then it shuts down...then purrs for about 5 seconds then silent...thanks for nay help - Dan0 -
carlin
if it is a carlin burner, ther's a good chance the end cone is coated with carbon. usual cause is too much draft, it pulls the fire away from end cone so the nasty stuff doesn't burn off like it should. very common in windy areas.0 -
Sounds like
flame continues after burner cuts out. You'd probably be best served by contacting your oil companys service dept or someone else qualified to take a look. I think service may be in order.0 -
Very common with 99FRD, Also need to check pump presure and angle of nozzle. Carlin's like 60 degree nozzles0
- 119 Chimneys & Flues
- 114 Geothermal
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
