Determining loop lengths
JimmyJam
Member Posts: 78
Any suggestions on how to determine loop lengths already installed in slab? I was called out to determine why a 10 year old radiant floor heating system has never kept up in cold weather, I found an office area of approximately 750 sq ft, 75' away from supply and return manifolds to be serviced by (2) 1/2" loops (or so the owner states). The loops are supplied off the same manifold as a 1,700 sq ft. shop area that he has valved off as equipment in this area produces enough heat for this area. (This area we believe is serviced by 5 loops of 1/2" tubing.)Copper fin boiler was installed about 6 years ago and of course trips on limit when office area calls for heat, previous contractor has (2) 26-96 pumps in series which tells me???? So to make a long story even longer, is there any way to determine loop lengths that may have been installed for office area? I will need to replumb manifold system but want to determine whether I can correct office heating problem with installed loops.
Thanks for any help!
You are in luck
with compression fittings on the various loops you could disconnect and use a garden hose to fill and purge a loop. Then use an air compressor to blow out the water into a bucket and measure the amount.
Make sure you have a compressor with enough fizz (pressure and cfm) to completly blow out the water.
The water can then be converted into loop length. 1/2" pex (1/2" id) holds .920 gallons per 100 feet of tube.
hot rod
Thanks Hotrod!
This is why I visit this sight so often!!!! Does anyone know what the manufacturer is of this tubing? It looks similar to Rehau but has a deeper reddish color to it and I have not pulled off manifold to see if it is PAP pipe yet.0 -
Looks a lot like
DuraPex. It was also sold under the Heatway or Watts Radiant name for awhile. It was sold as a non barrier plumbing tube, dull finish no EVOH barrier.
hot rod
loop lengths
are there any labels, markings on the tube?? the tupe if been installing is labeled every two feet from 2 ft to 600 ft,if your lucky enough to read them you could figure out the loop length. good luck..........mike0
- 167 Indoor-Air Quality
