tt contacts = turn on taco
I wonder why this did'nt work?
  • If you wired
    the hot leg of 110 volts to one side of the end switch and the black wire to the pump to the other side of the end switch, the pump will turn on whenever a zone calls for heat. Jumper the neutral wires together.
  • Michal
    Michal Member Posts: 213
    do you really want an answer on that
    If you really want an answer whoever did that is a dumb ****. Whats the deal with the low voltage wire, If this si a joke fine, if you are seriously asking well you have issues.TT terminals are connected to the thermostat
    The circ is wired using 12 gauge wire to the c-1 terminal on a aquastat and the white wire to the c-2 terminal or neutral terminal.
  • Robert O'Connor_3
    Robert O'Connor_3 Member Posts: 272
    I am not looking for an answer as to why this is not working. That is obvious, I was just sharing something stupid that I found last week.
