tt contacts = turn on taco
Robert O'Connor_3
Member Posts: 272
I wonder why this did'nt work?
If you wired
the hot leg of 110 volts to one side of the end switch and the black wire to the pump to the other side of the end switch, the pump will turn on whenever a zone calls for heat. Jumper the neutral wires together.
do you really want an answer on that
If you really want an answer whoever did that is a dumb ****. Whats the deal with the low voltage wire, If this si a joke fine, if you are seriously asking well you have issues.TT terminals are connected to the thermostat
The circ is wired using 12 gauge wire to the c-1 terminal on a aquastat and the white wire to the c-2 terminal or neutral terminal.0 -
I am not looking for an answer as to why this is not working. That is obvious, I was just sharing something stupid that I found last week.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
