hot water recirculating pipe
bwinn
Member Posts: 2
how do i pipe a recirculating pipe from the hot water tank. where can i get the information.
recirculating
how do i pipe a recirculating pipe from the hot water tank. where can i get the information.0 -
Taco, recirulation pump 003-PNP
Attached is an instruction sheet, and submittal data information for the Taco, 003 plumb & Plug, with a timer, and 6 ft pig tail to facilitate wiring. The instruction sheet has a diagram of a typical piping layout.
Taco, Inc.
Joe Mattiello
Technical Service Technician
joemat@taco-hvac.com
401-942-8000 X 484
www.taco-hvac.comJoe Mattiello
Taco Comfort Solutions0 -
hot water recirc
When you pipe a hot water recirc you must put a check valve on cold water inlet, I usually use a taco 006 bronze circulator and wire it with out an aquastat so the circulator runs continuously. some guys like to use an aquastat. it has been a while since i have done one the only other thing is an expansion tank i was told to always put one in but recently a contractor friend told me you dont need one the water heater acts as the expansion tank. hope i could help0 -
Ummm
The only way that water heater will help alleviate expansion is to leave it shut off. Your contractor friend's advice is bad.0 -
i like the 004 1/2.....
now the 003 well it is a small miricale that i have even 006 1/2" ...getting a 003 now That would be trick
......run back from th 'T' from the furthest fixture tie the line into the cold water supply to the water heater of your choise put a check on both the hot (recirc) and the cold. cut a 'T' in for an st- 12 or st-15 on the cold water ....good day
Try...
...www.gothotwater.com . You don't need a separate recirc line at all.
Yours, Larry0 -
Expansion tank
Oh it (water heater) will act as an expansion tank alright. As it crushes the flue pipe.0 -
Gdog
I suspect what you friend meant was the well trol tank may act as an expension tank?
If you are on a well system and there are no checks between the well tank and HW tank.
hot rod
expansion tank
I called him after i posted that message and we discussed it further he was wrong with his theory and i was right sorry gor the false info0
- 167 Indoor-Air Quality
