Heating my Garage
I am going to finish off my garage. Would a separate water heater system work to heat it. What do you suggest.
  • Dof3
    Dof3 Member Posts: 120
    infloor
    Is this an infloor job? If so have a heat load done on it. If it is installed right and insulated,a water heater might work.
  • David Wiechmann
    David Wiechmann Member Posts: 2
    The garage has a floor already so infloor would be difficult. I have a gas hot water system in the house.
  • Jack_21
    Jack_21 Member Posts: 99
    Garage heat
    I heat my garage iwth a Rinnai Energysaver 1004. Gas fired direct vent. Sealed combustion, which in a garage is expecially important. Not inexpensive, but you get what you pay for. www.rinnai.us
  • harvey
    harvey Member Posts: 153
    garage heat
    Look at Detroit radiant infrared heaters. They are making a two stage residential unit that can be hung at 8'
  • hr
    hr Member Posts: 6,106
    If you
    have a boiler already, and it has a bit of extra capacity, consider a hydronic unit heater. Modine and others make various sizes.
    This would be a simple install and a fairly easy retro fit. Fairly quick recovery if sized correct :)
    hot rod
