piping toekick heaters
Angelo_2
Angelo_2 Member Posts: 1
Iam adding two toekick heaters to an excisting finned baseboard run it is a typical two pipe system on its own zone i dont want to cause excessive pressure drop by going in and out the toekicks and then the baseboard where and should i use monoflow tees ? the toekicks are on the same level as the loop piping.
