piping toekick heaters
Angelo_2
Member Posts: 1
Iam adding two toekick heaters to an excisting finned baseboard run it is a typical two pipe system on its own zone i dont want to cause excessive pressure drop by going in and out the toekicks and then the baseboard where and should i use monoflow tees ? the toekicks are on the same level as the loop piping.
You didn't like the answers you got 2 weeks ago?
http://forums.invision.net/Thread.cfm?CFApp=2&&Message_ID=158386&_#Message1583860
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
