buderus indirects water heaters
shawn_5
shawn_5 Member Posts: 52
Has anyone had problems with the well on the indirect water heaters The last 3 have been irratic temp.today I had to set the control to 110 degrees to get 130 degrees I use all the parts the two inserts and the tension wafer and it is pain to get in there.Is it any easier using the logamatic.and would heat transfer compound work.any thoughts
