buderus indirects water heaters
shawn_5
Member Posts: 52
Has anyone had problems with the well on the indirect water heaters The last 3 have been irratic temp.today I had to set the control to 110 degrees to get 130 degrees I use all the parts the two inserts and the tension wafer and it is pain to get in there.Is it any easier using the logamatic.and would heat transfer compound work.any thoughts
NOBODY HAS HAD THESE ISSUES
Shawn
What control are you using ? You asked if it was easyer to use the logomatic, what are you using now thats giving you trouble ?
Scott
which control?
Are you using a Honeywell aquastat or the sensor for the Logamatic control?0 -
honeywell aquastat0 -
i would try
a little heat transfer compound.0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
