Arow Oil Burner Cuts out
R Dakin
Member Posts: 2
I need a little help here please! I have changed the oil filter, pump screen, transformer, nozzle, primary control, and cad cell and nothing seems stop it from cutting out. It has a .03 breech draft and a 0.02 over fire. Help please any suggentions
Arow or Aero
Is this a Aero burner with a 3450 motor?0 -
whats cutting out?
is it the cadd cell thats cutting out or the thermal overload on the motor. I just had where my burner was cutting out on thermal overload and then as a result the cad cell would lock out. The conclusion and solution was that the fuel line had a obstrucytion. So I blew out the line from the filer back with 100 pounds of air from a compressor, and so far so good. i did the same, changed filter, pump, etc and guys here gave me ideas and i blew the line out. try it0 -
Burner motor probably has a dead spot0 -
Were the lines buried??
Cant say I'm a huge fan of "blowing out" oil lines. Thats just asking for trouble. Could lead to more than the initial problem. I would do that as an absolute last resort. Try a hand(vacuum) pump and a vacuum gauge on the line. Eliminate the guess work. JMO.0 -
Is it possible to have a dead spot in the burner motor and would i see a difference at all in the pump pressure.0 -
pressure change
honestly I do not think you will see a pressure change, I think its a point in the motor where if it lands on it, it will not turn over, its a internal thing, But since I blew out my lines, its been fine.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
