Paper below aluminum plates and pex?
Any barrier in an application with or without> (heaven forbid) <plates should be under the emitters. Move the heat in the desired direction you desire. Your post is quite unclear. Please rephrase.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=296&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
paper above subfloor
Can a system be installed using pex and aluminum plates above an insulated crawlspace with out the use of any type of vapor barrier between the aluminum plates and the subfloor? Seems like you wouldn't need one because the floor is heated by the radiant.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 996 Plumbing
- 391 Solar
- 55 Water Quality
