Where to buy 45/64 bit for 1/2-inch NPT Thread Tap
Steve Garson
Member Posts: 191
I just bought a tap at the local plumbing supply house and am amazed to find that almost no one sells the 45/64-inch bit that it requires. Even online! Am I missing something?
What size bits do you guys use when you need to tap a 1/2-inch hole?
re
mscdirect.com
also if there is a good industrial supply house, or a real hardware store around, they will have one.0 -
drill bit
grainger has them0 -
11/16
would be the same real close to 45/64 . best wishes J.Lockard0 -
45/64 is definitely out there in many varieties. HSS and exotics in normal drill bits of full-size and reduced shank, router bits and even high-precision masonary bits for drilling bowling balls!
Vermont American makes the regular drill bits, but doubt that they're considered "common" stock in most places.0 -
drill bit
must have your numbers wrong. 45/64 is almost 3/4" Can't run a 1/2 tap through a 3/4" hole. Maybe 25/64 or close to that? Anyway Grainger will have them.0 -
Drill bit
45/64 (.7031) IS the correct tap drill size for a 1/2-14 NPT hole. We use an 18 mm drill (.708). It works fine (we make hundreds of 1/2" NPT holes in steel pipe every day)0 -
The outside
of the pipe Dennis. 7/8" is the outside diameter +/-. Best Wishes J.Lockard0 -
Fastenal
Do you have a local fastenal?0 -
7 corners hardware
7 corners hardware in St. Paul, Mn. They have more in that store than most tool warehouses. www.7corners.com0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
