Circ's in Series
Tom_32
Member Posts: 8
If you put two circulators in series in a closed loop system , do they have to have exactly the same specifications? I am working on a ground loop system that has two Taco 0013 circulators and one is bad. I want to replace the bad one with a Grundfoss UPS26-116. The spec's are almost the same but not exactly. Is this a problem?
Series
You shouldn't have any problem. Without both pump curves and the system curve I can't tell exactly but if the pumpcurves are close you shouldn't notice much difference. bob0 -
well if they are off a bit, they will "ride the curve" and find a happy output of head and gpm, You should be fine if they are a bit different, but as said try to match as close as possible0 -
Thanks for the help!0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
