Circ's in Series
Tom_32
Member Posts: 8
If you put two circulators in series in a closed loop system , do they have to have exactly the same specifications? I am working on a ground loop system that has two Taco 0013 circulators and one is bad. I want to replace the bad one with a Grundfoss UPS26-116. The spec's are almost the same but not exactly. Is this a problem?
Series
You shouldn't have any problem. Without both pump curves and the system curve I can't tell exactly but if the pumpcurves are close you shouldn't notice much difference. bob0 -
well if they are off a bit, they will "ride the curve" and find a happy output of head and gpm, You should be fine if they are a bit different, but as said try to match as close as possible0 -
Thanks for the help!0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
