venting steam mains
John Shea
Member Posts: 247
to tap the side of the steam main, then come out with a short nipple then an elbow up?
Sure is
I frequently do this. When you tap the hole, hold the tap at a slight upward angle. This will pitch the horizontal nipple slightly back toward the steam main.
Best place to drill and tap is in the side of the last tee supplying a runout.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"All Steamed Up, Inc.
Consulting0 -
Thanks Steamhead.
That will work perfectly in this situation. The T will provide good 'meat' as well. As always, thank you.0
- 50 Industry Classes
