buderus gb142 piping question
We are installing a GB 142 wall hung boiler in a house that we are doing the radiant on, the house has 140,000 btu's of heat loss, 12 zones, 2 temps. Temp # 1 (106 deg.) has a load of 58,000 btu's w/ a flow of 9 gpm. Temp # 2 (126 deg.)has a load of 73,000 btu's w/ a flow of 11 gpm. There is an inderect fired w.h. but no other heating loads on the system. My question is the piping diagram I downloaded off their application manual has two 3-way mixing valves connected to an outdoor reset. Would a taco radiant mixing block work instead of these TC-62 3-way valves. it would be less exspensive to pipe (labor and materials), but would it be as good? what do you guys think?.
My goal is constant circulation.
I will try to attach page 28 of thier application manual in the morning to show you what i'm talking about.
thanks
