richardson and boynton return line check valve
I HAVE A RICHARDSON AND BOYTON VAPOR SYSTEM IN MY HOME, AT THE RETURN LINE AT THE END OF THE RADIATOR, IN THE ELBOW IS SOME KIND OF VALVE WHICH SEEMS TO HAVE FAILED. THE RADIATOR IS NOT GETTING HOT ACROSS ALL THE SECTIONS AND IS NOT HOT ENOUGH TO KEEP THE ROOM WARM. DOES ANYONE KNOW WHERE THESE VALVES CAN BE FOUND OR CAN I USE A STEAM TRAP IN PLACE OF THE OLD VALVE?
