Riser vent size
David Lake
Member Posts: 2
Which Gorton vent should I use at the top of each riser if the risers are 1 1/2" pipe with a length of approximately 50 feet? I suspect a Gorton #1 or D.
Can't tell you how much I appreciate the responses I have received on the this site! Thanks!
David
David
Either will work fine
the #D would be my choice, since it only needs a 1/8" pipe thread hole in the pipe.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"Baltimore, MD, USA
Consulting0
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
