Riser vent size
Which Gorton vent should I use at the top of each riser if the risers are 1 1/2" pipe with a length of approximately 50 feet? I suspect a Gorton #1 or D.
Can't tell you how much I appreciate the responses I have received on the this site! Thanks!
David
