Bench Radiator
Chip
Member Posts: 1
While looking for a bench radiator for a main entry application; I've been dealing with sticker shock. Any ideas or suggestions where I might find some different sources?
I have a csutomer
who is also looking for a bench radiator. He saw a picture on a Buderus flyer, but there's nothing on their web site or catolog about it. What brands have you found so far?? WW
what about....
finding an old window radiator from an old gravity hot water system and put a seat on it? My parents house has 3 or 4 in them. Great for warming up your buns! kpc
Frank Plumbing Sales 612 338 7609 Minneapolis, IF your'e in the Midwest.0 -
Doing It
I make custom bench seat rads often. I use steel fin tube (Slant-Fin 530 with M1 brackets) and have the GC build the seat according to the specs noted in Hot Tech Topics. The bench seat must have a 2" air slot at the base of the bench and at the top to allow air to circulate. If the spec is not followed, it won't work. Often a Danfoss remote TRV can be installed to allow control over the heat output.
Here's a Pic
Finished bench seat in mahogony with cedar lined interior for blanket storage. (4ft. steel fin tube within)Notice the bottom and top air circulation grills.
That's beautiful!
No problems with the wood warping? Max. water temp? It looks very enclosed?0 -
Bench Radiator
On our website, look in the Panel Radiator Design Manual and there is a drawing of the Bench Radiators we offer. If there are any questions, please give us a call. Thanks0 -
This Is From...
... the old Audel's "Plumbers & Steamfitters Guide".0 -
Bench seat details
here are some detail pics. The carpenter made an access panel to bleed the radiators without compromising the cedar interior.
Acclimation
The wood was acclimated for 30 days onsite before the cabinets were made. The interior of the seat can reach 140-150 degrees, so woods should be selected carefully.
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
