taco circulators
grindog
Member Posts: 121
what taco circ is the best to use in indirect water heater applications have a fourty gallon tank next to boiler what size should i use
what taco circ is the best to use in indirect water heater applications have a fourty gallon tank next to boiler what size should i use0 -
a 007 should work fine0 -
Taco, 007-F5-IFC in most cases
The Taco, 007-F5-IFC will do a nice job in most cases. However, to size pump properly you need to know the pressure drop across the coil. The 007 IFC with the integral flow check will out perform the standard 007, because you do not have the pressure drop across the flow check, which can be as high as 63 ft, for a 1". Additionally, the IFC saves time, and money. The way I look at it is more money for Sundays Super Bowl Party!! Go Pats!! Attached is the submittal data information for the 007
Taco, Inc.
Joe Mattiello
Technical Service Technician
joemat@taco-hvac.com
401-942-8000 X 484
www.taco-hvac.comJoe Mattiello
Taco Comfort Solutions0 -
Taco circs
I install Vaughn Top Performers and always use 008. EJW0
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
