Success stories for boiler control W/modem for remote access.
dave_58
Member Posts: 2
I'm looking to hear if anyone feels strongly about a boiler control that offers user interaction remotely via internet. Any success stories out there in the residential market?
I know it doesn't mean much...
... but the Viessmann stand at ISH was showing off their KM Bus system, or whatever, that allows a small server to interact with the Vitotronic system. The house that they were monitoring was in Canada, showing all circuits, boiler operation, etc. You could even change the temperature, etc. IIRC, it required a Vitotronic 300 control, an-add on brain, and lots of dough.
Some people have had very good success with the X10 system of distributed controls, thermostats, thermistors, etc. This is likely to be a much less costly solution than the Viessmann system. However, many people find X10 fiddly to set up, so the alleged plug-and-play features of the Viessmann system do have that appeal.0 -
Whole house system
I appreciate your response. I know there are some whole house monitoring systems out there.(lighting, heating, security) and I have done some work on proprietary commercial systems. (lots of $) I am also aware of a remote monitor system for Grudfos SQE pumps.
Just wondering if anyone has any other thoughts about this?0 -
remote controls
I am presently using a sensaphone remote. The only remote feature is to allow me to turn my heat up or down to preset numbers. An example being 55 away degrees and 72 at degrees. Allows me to turn my heat on before I arrive. But it will also monitor a number of systems and give you a call if there is a problem. Examples are: smoke detectors, low temperature, water leaks, intrusion alarm and a number of others. Tekmar also has an occupied and unoccupied feature with preset temperatures that work well.0 -
Dial in remote control packages
Try this website.
This manufacture has done a great job in user interaction.
Check it out and if you have questions call Karl Blackmore at the listed phone number for more information.
http://www.hbxcontrols.com0 -
Honeywell enviracom?
Thank you for the feedback. I've been looking at options.
Has anyone tried using an enviracom, say with a 363 tekmar as the primary reset. The enviracom has an interface to monitor zones and allows user setbacks. All the 363 inst/adv settings shouldn't ever be exposed to the client anyway. My only concern is using forced air stat technology for radiant floor, however the control does use outdoor sensors and claims to operate within 1 degree. Any thoughts on how this might work?0 -
i have yet to install buh...Caleffi.
the as seen on computer monitor part looks sharp however i havent installed one nor have i studied the finer intracies of the enviro com....for now i pretty much bought into the Caleffi and am sure that it is "for me" as it were..none of these controls are bargin basement items i checked out the link in the post above and it may work for you also ...it is expandable...0 -
I may try the enviracom and see how it works. Currently discussing this with a home automation company. I'll keep you up on what I find. Thanks0 -
iRadiant Controls with Internet access
We've done hundreds of projects with the iRadiant controls. Simple data server hook up gives you web browser capability to view, graph even configure the entire system over the internet. Service calls can be sent to you via email or any web enabled device. You know what's wrong before you get there!
You can do TCP/IP, dial up, or Lan. Cost, frankly not much more than you'd pay for stand alone controls. Take a look at the web site www.caleffi.us. Western Nevada Supply has done quite a few jobs with this. If you're interested, I'll give you the password so that you can look at a working site.
Sincerely,
Roger Michaud
Caleffi0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 947 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
