Two techs later and hoping u can help
Terry_11
Terry_11 Member Posts: 7
As previously statem is not , really not leaking we checked the. the exhaust from the chimney is not white smoke it is regular a hint of black.
i am still not able to generate PSI the gauge is not regestering any and pressure release valve is not shooting out steam just a small trickle
made sure pipes are pitched for dry steam mains
please help
  • Paul Mitchell_2
    Paul Mitchell_2 Member Posts: 184
    Something
    happened between the previous years and now. No matter how small or silly it was it had a big effect on your system. You know the answer just think about it."It heated fine untill this year"...Did you remove asbestos????
