Two techs later and hoping u can help
Terry_11
Member Posts: 7
As previously statem is not , really not leaking we checked the. the exhaust from the chimney is not white smoke it is regular a hint of black.
i am still not able to generate PSI the gauge is not regestering any and pressure release valve is not shooting out steam just a small trickle
made sure pipes are pitched for dry steam mains
please help
please help
Something
happened between the previous years and now. No matter how small or silly it was it had a big effect on your system. You know the answer just think about it."It heated fine untill this year"...Did you remove asbestos????0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
