I have no Heat but I have Hot Water... What is wrong???
Johnny7
Member Posts: 4
Hi,
I live in a condo in Brooklyn and have no heat.. However, I have hot water. When I go to the basement to the boiler (Burnham) room the pipes are hot. At first I thought it was my thermostat but I dont think thats the problem because when I move the slider I see a spark in the mercury. The heat worked the whole winter last year and hasn't worked this season. Any suggestions??
I have no heat but I have Hot Water
Hi,
I live in a condo in Brooklyn and have no heat.. However, I have hot water. When I go to the basement to the boiler (Burnham) room the pipes are hot. At first I thought it was my thermostat but I dont think thats the problem because when I move the slider I see a spark in the mercury. I think I have a hot water system with baseboard heat. The heat worked the whole winter last year and hasn't worked this season. Any suggestions??
Thanks,
Johnny0 -
sounds like
It sound's like it's in your control system or circulator system. Sound's like the boiler is to temp just no way to get it to the baseboard. You need a pro to diagnose the problem...0 -
Thanks for the quick reply!! How much do you think that it should cost to fix and is this a big job?0 -
You may also want to check if air is in the pipes, your heating professional may have to bleed the system.0 -
impossible t o tell
Could be the ciculator, could be air in the pipes, could be a bad relay.
Who knows what the rates are in your area.
Bottom line is you have no heat and unless your happy that way you need someone to fix it. Stop worrying about the price and call someone.. really.
Scott
Condo?
Doesn't your building have someone to maintain the heating system?
Is it the building's boiler or do you make your own heat/hotwater?
All owners have their own boilers.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
- 49 Industry Classes
