Little Red Booster Pump
Jason laurelton
Member Posts: 13
I've just finished adding the copper pipe and Slant fine baseboard to my basement. I purchased a B&G Little Red booster pump. My problem I'm having problems setting up the thermostat. The thermostat & transformer to control the pump. The pump gets powered but is not being controlled by the thermostat. Is there anything I'm missing ?
Are you using...
a switching relay to control the pump and turn on the burner, or just a plain transformer?0 -
I'm using a plain transformer to try to get the booster to turn on.0 -
Yes, missing this
- 167 Indoor-Air Quality
