Digital thermostats for Steam boiler
peter fazekas
Member Posts: 1
Can anyone recommend a good programmable thermostat that will work for a steam boiler? Do they even exist?
Honeywell
> they even exist?
Honeywell
Makes quite a few. Make sure you adjust the cycle rate for steam.
cycle rate (-thermostat novice)
What is a reasonable setting? I'm sure there are some factors involved. By setting the cycle rate, I assume you mean to do so via an anticipator adjustment?
I've been told that there's no calibrating the anicipator setting on digital tstats. Is this true?0 -
i've worked with honeywell t-stats and all of them have an installer setup, the cycle rate is in the installer setup. some home depot specials have set screws and whatnot to do the same thing. steam heat typically has a cycle rate of "1" on digital t-stats. make sure you buy a battery powered stat otherwise you might find out the hard way that your transformer de-energizes when the pressuretrol setting is met.0 -
Outdoor Reset
Hello,
If you are interested in saving on your fuel costs you may consider using a tekmar Boiler Control 269 to provide outdoor reset to single steam boiler systems. The control is mainly designed for commercial applications, but could be used in residential applications as well.
For more information check the tekmar website under products.
Jay www.tekmarcontrols.com0 -
We've got a new one...
The TH8110U1003 VisionPro is ideal for steam. Digital, touch-screen display, battery powered, 7-day programming. Just set it for 1 cycle per hour, using the touch screen,(the screws are only found on older and retail models) and it should work fine for you. For more info, go to www.honeywell.com, and follow the prompts. Avaialble from any Honeywell distributor, or your local heating pro.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
