Taco Paneltrol
Mike Reavis_2
Member Posts: 295
Do you have any idea how old these mixing valves are? How about pressure drop across them to give me an idea what size circulator I would need.
Mike
Mike
mike
I sold these in late 60's I'll look for some old info I may have. I think taco stopped mfgr. in early 70's. if
I can find anything I'll get back to you0 -
Taco Paneltrol
There's a reference here in "The Library" about Taco Paneltrol mixing valves.0 -
The house and the boiler date from the late 50's
thanks0 -
thank you
Taco Paneltrol/5000 series
Attached is a submittal data sheet for the old Taco paneltrol Taco mixing valve. If you need to replace the valve try the Taco 5000 series. For your reference I attached the submittal data sheet.
Taco, Inc.
Joe Mattiello
Technical Service Technician
joemat@taco-hvac.com
401-942-8000 X 484
www.taco-hvac.comJoe Mattiello
Taco Comfort Solutions0 -
Whoa, Joe--Who'z betta than you?
Thanks,
Mike0
