Buderus Install
S Davis
S Davis Member Posts: 491
This is our latest Buderus install in seattle WA.
S Davis
Apex Radiant Heating
  • Mark Eatherton1
    Mark Eatherton1 Member Posts: 2,542
    Nice work Stacey!
    How do you like your Pro Press. My partner is not convinced that its worth it...but he's "old school".
    Kudos to you and your crews.
    ME
  • John R Leny
    John R Leny Member Posts: 14
    Very Nice
    Awesome. You take pride in your work and it shows. As a builder/realtor I appreciate a neat and clean install. I wish there were more like you.
  • Robert O'Connor_7
    Robert O'Connor_7 Member Posts: 688
    NASA...
    Looks like mission control! Great Job! In the first pic, the control with the little red light, is that to interlock a combustion air damper?? Glad to see you western folk raising the bar..Robert O'Connor/NJ
  • S Davis
    Pro-Press
    It saves alot of time on installs but where it really shines is in repair work.
    We did have a problem with some bad 1" male adapters that would leak at the threads but the nice thing is you can still tighten the fitting after you press it you just re-press it after.
    Thanks we try to make every install look its best.
    S Davis
  • S Davis
    Relay
    Robert that is a relay to fire the floor pump and main loop pump.
    S Davis
  • S Davis
    Thanks
    Thanks John we are usually the high biders so we dont get every job but we include alot of things other heating contractors in our area leave out, like LWCO,manual reset high limits, 009 backflow preventers to name a few.
    S Davis
  • Larry_10
    Larry_10 Member Posts: 127
    what is the boilermate next to the buderus
    nice job on your install
  • dconnors
    dconnors Member Posts: 215
    nice install
    I see you had to strap in the Amtrol. Is that because it feels inadequate sitting next to such a fine boiler? (just kidding). Really nice job.
  • Dan_15
    Dan_15 Member Posts: 388
    Not taking in fresh air from outside?
  • S Davis
    Combustion Air
    Yes we are taking air from outside it is behind the boiler and exits the room about 18" above the floor. when they cored the hole through the concrete wall for the venting they only gave us a 4" hole so we could not use the concentric vent kit that is supplied with the boiler we had them core another hole low for the combustion air to avoid cross contamination.
    Are you the Joe I talked to at Tech support yesterday?
    S Davis
  • soot_seeker_3
    soot_seeker_3 Member Posts: 12
    which tekmar?
    which tekmar is that(with the gold? front panel)?
    ss
  • Dan_15
    Yes, I am the Joe you spoke with. I am the only Joe here at Buderus. The install looks good. Thanks for the pictures!
  • S Davis
    Tekmar
    It is a 356 variable speed mixing control.
    S Davis
  • Nice , very nice work
    The Propress fittings make it look like a vintage system , something from turn of the century . Are the fittings readily available where you work ?
    I also like the fastening system you use . Can you tell me the brand name of the clamps and where you find em ? I'd like to use them in my own home . Beautiful work Mr. Davis .
  • S Davis
    Propress
    Ron,
    When we swiched to propress and bought the tool one of the conditions was our supplier would stock the fittings, the clamps are called Cush-a-clamps or another name is Hydrozorb clamps you should be able to get them from a plumbing supply or refigeration supply house.
    Thanks for the kind words about our work.
    S Davis
  • Ted_9
    Ted_9 Member Posts: 1,718
    Beautiful copper work. Nice install.
    What is the tan controler on the wall? Is that the Tekmar? Its not blue?
    PATRIOT HEATING & COOLING, INC.
  • Mitch_4
    Mitch_4 Member Posts: 955
    Beautiful
    The only thing I could suggest to totally polish the job is stickers for the switch boxes instead of markers. I used markers for years too , but I now get stickers and it just adds a nice touch.
    But that is so minor. Beautiful layout
  • tim smith
    tim smith Member Posts: 2,935
    Buderus install
    Good looking work, cush clamps are great, have used hundreds, little spendy but good product.
  • S Davis
    Electrician
    I know the electrician did that and I didn't have another cover to replace it with.
    Thanks
    S Davis
  • S Davis
    Tekmar
    It is a Tekmar 356 mixing control.
    S Davis
