Heating loop length
Paul_28
Member Posts: 113
What is the maximum length heating loop the can be made with ¾ inch copper pipe?
Like most things in hydronics the answer is, "it depends."
But, using the below generally regarded "safe" parameters of:
1) 20° temperature drop in the loop
2) 1 gpm flow
3) 170° AVERAGE water temperature (assumes 180° supply and 20° temperature drop)
4) 480 btu/hr per foot of baseboard (65° entering air)
One gallon per minute of flow @ 20° temperature drop gives you 10,000 btu/hr to work with.
10,000 / 480 = 20.833' of baseboard max @ 1 gpm.
With 2 gpm of flow @ 20° temperature drop you get 20,000 btu/hr to work with.
20,000 / 480 = 41.666' of baseboard max @ 2 gpm.
With 3 gpm of flow @ 20° temperature drop you get 30,000 btu/hr to work with.
30,000 / 480 = 62.5' of baseboard max @ 3 gpm.
With 4 gpm of flow @ 20° temperature drop you get 40,000 btu/hr to work with. 4 gpm is the the highest recommended flow rate and baseboard output can now be considered to be 510 btu/hr per foot with 4 gpm of flow.
40,000 / 510 = 78.43' of baseboard max @ 4 gpm.
To compute flow you must first find the head loss in the loop including all fittings, etc. Then select a circulator that will move the desired amount of water at that head loss.
If you design for a 30° temperature drop in the loop (again considered near the maximum safe design level) each gallon per minute of flow will now move 15,000 btu/hr. BUT, the average temperature will now be lower at about 165° (assuming 180° supply) so each foot of baseboard will be putting out slightly less heat.0 -
Thank you
> depends."
> 1) 20°
> 2) 1 gpm
> flow
> drop)
> (65° entering
> air)
> One gallon
> 10,000 / 480 =
> gpm.
> With 2 gpm
> baseboard max @ 2
> gpm.
> With 3 gpm
> baseboard max @ 3
> gpm.
> With 4 gpm
> 4 gpm of flow.
> baseboard max @ 4
> gpm.
> To compute
> water at that head
> loss.
> If you
- 110 Chimneys & Flues
- 982 Plumbing
- 387 Solar
