Buderus 2109 Controler For Sale
Larry_10
Member Posts: 127
I just had my new buderus installed for one month now and I am upgrading my controller to a 2107 so I am selling my 2109 for $125 free shipping if interested email me jason0438@hotmail.com include manuals
this unit works like new and looks like new because it is new
this unit cost $280 new I will take $125
thanks
thanks
buderus 2109
i just installed a Buderus g115/34 and i opted for just the 8124 control(the cheap way) what are the features of the 2109 - i'm running 4 zones --3 heat 1 domestic older Amtrol tank w/aqaustat controller -honeywell zone valves -single pump --what would the control do for me?0 -
i would call buderus and ask more info if you need but here is the info on it http://www.buderus.net/Portals/0/Lit-HS2109-CB-01.pdf
thanks
i haven't the time to call -i'm on the early grave shift since last saturday --8:00 a.m till i'm done --i'm in up to my ears with calls and getting burnt-out the owner is in Florida -family emergency and i have 1 guy out w/back problems and another i told to go f-himself and stay home--so in a 6 mechanic shop i'm down to 3 myself the other guy is best suited for piping and heavy mechanical not service-- 1 guy who runs the cleaning crew and his helper ////////---any way the only question i think would be the room sensor --situation -i have 3 stats 3 different heat losses -can this be run constant circulation out door reset w 3 different sensors or does there have to 1 central room sensor and how would the domestic be sensed using the amtrol w/the older control------- i'm going to nap now //that took what little energy i had left --7 more calls to do --if i wake up0 -
I feel for you man hang in there. this control is not for outdoor reset it dose not need a outdoor sensor it's a high limit aquastat you can set the circulators on constant circulation or you can let them run for tem mins after a call for heat the control is for a cold start boiler you will have to look at the brochure to see what it can do
good luck
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 999 Plumbing
- 391 Solar
- 55 Water Quality
- 45 Industry Classes
