Melting Downspout
joel_19
Member Posts: 933
I have a commercial building with frozen downspouts. They are frozen because they are full of condensate from 90+ furnaces (engineer's brilliant idea). I have a pipe thawing machine - what do you think of the feasability of thawing the downspouts with the pipe thawing machine. Obviously not a permanent solution. But we have to do something right now until we find a permanent solution.
Go for it...
> permanent solution.
Joel,
While thats going on take a look at Raychem electric
heat tracing commercial - industrial grade stuff for
freeze protection. should be available at most industial
supply houses, stay away from the garden variety stuff.
this is a good idea anyway regardless of the unconventional
means of condesate disposal.
if you have any questions email me, i've installed tons
of this stuff in process plants.
regards, don0 -
Go for it...
Joel,
means of condesate disposal, you might need to do the roof scuttles as well.
of tape, induction and steam tracing in process plants.
if this is a new building or an older retofit i'm suprised
that the a/e firm didn't include this in their scope of work, real standard stuff for quite a while now.
regards, don0 -
Frozen Downspouts
I have appox. 450 ft. of Reychem Wintergard Wet, heat cable. Part No. WGRD-H622-250. It's output is 6 watts per ft.@240VAC. It can be totally submerged and you can overlap it. It is made for the type application you have. You should use a thermostat to operate it, have it close when the temps drop below freezing. If you are interested in it, let me know for I will let it go at a decent price. Jon PS: This is the industrial heat cable Don has mentioned.0 -
He has first dibs...but let me know your price if he can't use it...john...0 -
price on Wintergard Wet Heat Cable
E-mail me at 6ppcn133@twcny.rr.com0 -
Joel & John Ref. Price on heat cable
I e-mailed Joel and have not recieved a response, but it looks as if my email did not get to him. So here is the price, a 250 ft. spool of Raychem Wintergard Wet, cost me last year at Graingers $1087.00 divided by 250 = $ 4.35 per ft. I overbought for the job and have 1 complete 250 fft spool and 1 with 200 ft on it for a total of 450 ft. for sale. If you take it all, you can have it for $1500.00 plus $30 shipping. That is less than $ 3.40 a ft. And that is the bottom price.0 -
Joel & John, Ref.: Price on heat cable
I have not heard from either of you on it after the price was quoted.0 -
it's an ok offering...still kicking it over...I did see a lower price than grainger on the web, but still above yours....
- 167 Indoor-Air Quality
