Melting Downspout
joel_19
joel_19 Member Posts: 933
I have a commercial building with frozen downspouts. They are frozen because they are full of condensate from 90+ furnaces (engineer's brilliant idea). I have a pipe thawing machine - what do you think of the feasability of thawing the downspouts with the pipe thawing machine. Obviously not a permanent solution. But we have to do something right now until we find a permanent solution.
  • don_52
    don_52 Member Posts: 199
    Go for it...
    > permanent solution.
    Joel,
    While thats going on take a look at Raychem electric
    heat tracing commercial - industrial grade stuff for
    freeze protection. should be available at most industial
    supply houses, stay away from the garden variety stuff.
    this is a good idea anyway regardless of the unconventional
    means of condesate disposal.
    if you have any questions email me, i've installed tons
    of this stuff in process plants.
    regards, don
  • don_52
  • don_52
  • don_52
    Go for it...
    Joel,
    means of condesate disposal, you might need to do the roof scuttles as well.
    of tape, induction and steam tracing in process plants.
    if this is a new building or an older retofit i'm suprised
    that the a/e firm didn't include this in their scope of work, real standard stuff for quite a while now.
    regards, don
  • Jon_2
    Jon_2 Member Posts: 109
    Frozen Downspouts
    I have appox. 450 ft. of Reychem Wintergard Wet, heat cable. Part No. WGRD-H622-250. It's output is 6 watts per ft.@240VAC. It can be totally submerged and you can overlap it. It is made for the type application you have. You should use a thermostat to operate it, have it close when the temps drop below freezing. If you are interested in it, let me know for I will let it go at a decent price. Jon PS: This is the industrial heat cable Don has mentioned.
  • john_27
    john_27 Member Posts: 195
    He has first dibs...but let me know your price if he can't use it...john...
  • Jon_2
    price on Wintergard Wet Heat Cable
    E-mail me at 6ppcn133@twcny.rr.com
  • Jon_2
    Joel & John Ref. Price on heat cable
    I e-mailed Joel and have not recieved a response, but it looks as if my email did not get to him. So here is the price, a 250 ft. spool of Raychem Wintergard Wet, cost me last year at Graingers $1087.00 divided by 250 = $ 4.35 per ft. I overbought for the job and have 1 complete 250 fft spool and 1 with 200 ft on it for a total of 450 ft. for sale. If you take it all, you can have it for $1500.00 plus $30 shipping. That is less than $ 3.40 a ft. And that is the bottom price.
  • Jon_2
    Joel & John, Ref.: Price on heat cable
    I have not heard from either of you on it after the price was quoted.
  • john_27
    it's an ok offering...still kicking it over...I did see a lower price than grainger on the web, but still above yours....
