Steam system baseboard??
Jeff_47
Member Posts: 1
I have a steam heating system and a delima. I have a bathroom which is very small. The radiator sits right next to the toilet and does not allow for much room when sitting. I had removed the radiator in the summer, but now the bathroom is cold. I could fit a low horizontal type hot water baseboard, but I'm not sure this is an option with steam heat. Anyone with a knowledge of the various heating products know of a solution? I'd really appreciate any feedback, thanks.
dan's book
get a copy of dan's book "the lost art of steam heating" he describes how to do steam baseboard the right way.
mark s0 -
Check out....
Steamradiators,com. They make a fairly thin single tubed product that just might free up enough space for you.
God luck. Chris0 -
steam baseboard.
Slatfin still rates some of its multi pack 80 for steam, I think others do also.
proper instilation will be critical.
http://www.slantfin.com/spec-multipak80.html
tuby0 -
Cast-iron Baseboard
is probably the way to go here. It will hold its heat just like a cast-iron radiator will, thereby matching the rest of the system.
Burnham, Governale, Slant/Fin and Weil-McLain all make cast-iron baseboard, but as far as I know only Burnham rates theirs for use with steam.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"All Steamed Up, Inc.
Consulting0 -
Thanks for all of your help on this problem. I have been trying to figure out how to make this work for a while now, without any luck. I'll be stopping at the local heating supply store today.0
