Steam system baseboard??
Jeff_47
Jeff_47 Member Posts: 1
I have a steam heating system and a delima. I have a bathroom which is very small. The radiator sits right next to the toilet and does not allow for much room when sitting. I had removed the radiator in the summer, but now the bathroom is cold. I could fit a low horizontal type hot water baseboard, but I'm not sure this is an option with steam heat. Anyone with a knowledge of the various heating products know of a solution? I'd really appreciate any feedback, thanks.
  • Hitzkup
    Hitzkup Member Posts: 63
    dan's book
    get a copy of dan's book "the lost art of steam heating" he describes how to do steam baseboard the right way.
    mark s
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    Check out....
    Steamradiators,com. They make a fairly thin single tubed product that just might free up enough space for you.
    God luck. Chris
  • tls_9
    tls_9 Member Posts: 89
    steam baseboard.
    Slatfin still rates some of its multi pack 80 for steam, I think others do also.
    proper instilation will be critical.
    http://www.slantfin.com/spec-multipak80.html
    tuby
    Steamhead Member Posts: 18,443
    Cast-iron Baseboard
    is probably the way to go here. It will hold its heat just like a cast-iron radiator will, thereby matching the rest of the system.
    Burnham, Governale, Slant/Fin and Weil-McLain all make cast-iron baseboard, but as far as I know only Burnham rates theirs for use with steam.
    Consulting
  • Jeff_48
    Jeff_48 Member Posts: 1
    Thanks for all of your help on this problem. I have been trying to figure out how to make this work for a while now, without any luck. I'll be stopping at the local heating supply store today.
