Balancing one-pipe steam
Steve Garson
Steve Garson Member Posts: 191
After installing new vents on the mains and lowerin the pressure a bit, I am amazed at how quickly my radiators heat up and how much less hot my basement is. Thanks for the advice Steamhead.
Today I installed a Gorton 4 vent on two radiators that before were not getting enough heat. Now everything is heating equally except for one tiny bathroom radiator that is getting zero steam. I even took the vent off to see if it would get steam but the temperature never elevated a degree.
Does this mean that the two new vents that I installed are venting too much? Is the problem that the pressure differential is too low, so the pressure isn't being maintained long enough to reach this one radiator, which by the way, is not on the far reach of the line, but on a riser to the first floor mid-way down the main line.
Thanks
