Wall hung Munchkin
Dof3
Dof3 Member Posts: 120
I just installed my 4th 80 Wall hung Munchkin. Do all of the main pipes come out at such a bad angle. The ones I got have the threaded 11/4" at such a bad angle down I have to put 45's on them to offset the pipes to get them staight. The boilers sure work good but, for the money they cost, the HO wants to know why those pipes can't be straight coming out of the boiler. Anybody else seen this?
  • hr
    hr Member Posts: 6,106
    I see that
    on cast iron and copper boilers also. If it's bad I start out with two 90's, as a swing joint to correct it.
    I use my REMS bender to adjust if I pipe copper from the boiler.
    hot rod
  • Ted_9
    Ted_9 Member Posts: 1,718
    Me and my associate have seen this too. If I use copper, I do a heat bend. Its better than crooked.
    PATRIOT HEATING & COOLING, INC.
  • Dof3
    REMS bender
    My REMS won't bend that big of copper. I do use fittings to offset and make it staight but man oh man that is kind of silly for the company to let something like that get through quality control. If you left the pipe crooked it makes you look bad,why don't they think the same way? Just my thoughts!!
  • Scott, k
    Scott, k Member Posts: 5
    makes us look bad
    Its the same thing with the oil tanks and the indirect hot water heaters, i hate it
  • DaveGateway
    DaveGateway Member Posts: 568
    Crooked connections
    Just installed a T80M and had the same problem. No good way to make it look nice.
  • Terry Larsell
    Terry Larsell Member Posts: 54
    Same with last one I put in, the plumber and home owner gave me a hard time about it. Sure looks hokey specialy when I push the product.
    All they have to do is put it in some sort of jig before they tighten the bands that hold it together. Maybe with there recent price increase they can spend the extra five minutes to get it right.
    Terry
  • Mike Reavis_2
    Mike Reavis_2 Member Posts: 295
    Whoa, HT Products call your office!
    I have not had the problem with a recently installed 50. But I believe it can happen. How about when a cast boiler gets that extra two or three rows of phantom threads at the back of the fitting--that can ruin your day. I usually get them to thread up though. I do my "Dirty Harry" routine and that usually gets it to cooperate. "...I've got to tell you the truth I've lost track myself. What you gotta ask yourself punk, is if your feelin' lucky."
  • Dof3
    What a relief!
    I sure am glad I am not the only one with this problem. Just a few minutes to make it right and staight. That is all I am asking!!
  • Leo G_99
    Leo G_99 Member Posts: 223
    send an e-mail
    to Chuck Shaw. This is the kinda thing that they (HTP) are looking , your and mine feedback! They will listen and do something about it. I have found HTP to be one of the most customer listening too companies there is!
    Leo G
  • Weezbo
    Weezbo Member Posts: 6,231
    it is as hot rod says..
    swing fittings .Ted is right also in that heating the urination out of the tubing and off seting it ,letting it cool,cleaning it,usually keeps the eye from darting straight to THAT fitting... swing fittings though are my prefered method. one other possibility is close by union it can take up some of the slack.:)
  • Dof3
    Eimail HTP
    Does anyone know the e-mail address for HTP? I would like to send them a note on this problem.
  • Scott, k
    HTP
    The E mail is www.htproducts.com there is a support section and you could list a complaint, I guess thats cool in a way.
  • Dof3
    Thanks!!
    Thanks for the info.
