Radiant heat under vanity
Matt_21
Matt_21 Member Posts: 140
under a vanity in a bathroom or cabinetry in a kitchen be added to the heat in a room or does the majority of it get trapped under the cabinets?
  • Carl PE
    Carl PE Member Posts: 203
    If it's on an outside wall, yes. Definitely help keep the plumbing from freezing.
    On an inside wall, I wouldn't bother. You'll just have hot shampoo.
    Of course, you'll find plenty of differences in opinion here.
  • hr
    hr Member Posts: 6,106
    Very little
    if there is the usual 4" air space between the floor and vanity bottom.
    Yes it will help with pipe freezing, although it shouldn't be below freezing temperatures below your vanity if the outside walls are insulated properly :)
    Cutting a small forced air grill in the toe kick will release some of the "locked up" heat.
    hot rod
