Radiant heat under vanity
Matt_21
Member Posts: 140
under a vanity in a bathroom or cabinetry in a kitchen be added to the heat in a room or does the majority of it get trapped under the cabinets?
If it's on an outside wall, yes. Definitely help keep the plumbing from freezing.
On an inside wall, I wouldn't bother. You'll just have hot shampoo.
Of course, you'll find plenty of differences in opinion here.0 -
Very little
if there is the usual 4" air space between the floor and vanity bottom.
Yes it will help with pipe freezing, although it shouldn't be below freezing temperatures below your vanity if the outside walls are insulated properly
Cutting a small forced air grill in the toe kick will release some of the "locked up" heat.
hot rod
- 87K THE MAIN WALL
- 57 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 991 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
